By bearbrad
#5140
:sweat_smile: hi ive experienced some issue about my clutch motor when i start stitching the power on the clutch motor is lossing is there a way that i could repair mine tnx for the answers :grinning:
By Mr. B
#5141
It could be the clutch is going out. From what i remember, it's a round cork thing that gets removed and replaced. If not, I have three clutch motors I will give you. pick up only.
#5143
I thought theres some adjustment on the clutch lever? Anyways this shows you how to clean the clutch friction cork and the flywheel which could be causing your problem.
