I fixed the foam. Previous owner I guess used spray foam. Just know it had sharp edges , I wouldn’t want my butt setting in it.
I just repaired the bottom part the two outside pieces the center insert is not replaced. I did replace a piece on the outer side cause it had to much sprayed on foam on it.
Hello everyone! It’s Dmitry_CAD here. F[…]
https://i.imgur.com/tqOXu7j.jpeg ⚠️ What Happens[…]
