- Fri Nov 03, 2023 2:07 pm
#16749
The second seat is finished and both seats installed. I realized that after adding padding to the second seat it threw off the measurements for the vinyl so I had to measure and make a pattern. Since I am a beginner, I used scrap vinyl, made a pattern, sewed it up to check for the fit(the pattern worked), took it all apart, cut the pattern out on the good vinyl, and sewed it up. It was a learning curve but I gained good experience in several areas. Great to have it completed and installed. Thank you to everyone who responded to my questions! My first project done.
Janet
Janet
