- Mon Aug 21, 2023 11:50 am
#16581
Rip in Side Cushion From a Short Distance.jpg (708.36 KiB) Viewed 2661 times
Rip in Side Cushion Close Up.jpg (698.68 KiB) Viewed 2661 times
Hello Everyone! I last asked for help in 2019. Then LIFE happened and I had little time for anything. I do now, and my husband and I purchased a second pontoon boat to redo. Our first one is on a lake in Minnesota and we don't get up there nearly enough to enjoy it. But when we do, I fall in love with it all over again.
Our second boat is newer and has a nicer type of seat. The corner 'seat' has an angle so that the passenger can lean against it while facing the driver. I'm starting with those two pieces as they seem the most difficult with their angles. Attached are pictures of a tear I caused just minutes ago when stapling the cover to the base between the two cushions. My question: is there any magical way to disguise this or repair it in such a way that it does not get worse? This is the second time I've sewn this. Odds are, I'm not going to take it all apart to replace that piece. This group has been amazingly helpful in the past. Thank you in advance for any help you can give me. The pictures show the cushion that has not been pulled tight and stapled at the bottom. Waiting to hear if I need to access the piece under the tear from behind. Neon
