By tjbii1
#15371
Looking for some help. I picked up a Brother LS2-B837 off of Facebook. Does the forum have a source for sewing machine parts? For the LS2 I need a needle bar and feed regulator spring. I’ve tried google typing in the part number there are several sources in Europe but they seem a bit shady. Is there something comparable that I could use? Thanks for your help. Thomas
They'll be hard to find. You can probably use consew 255 parts but it's a gamble. You can compare parts lists and see what you think.
(578.12 KiB) Downloaded 313 times
(1003.33 KiB) Downloaded 303 times
If you want to measure your needle bar, i can compare it to my 255
