- Sat Apr 30, 2022 6:27 pm
#15045
Hello Everyone!
I’m in the setting-up phase of my attempt to try my hand at some automotive interior work. This will all be for my own projects. I’m not a business, so being super efficient in my work space is not important. What I would like to do is get some opinions from the group about the table size they use for their industrial walking foot machines.
What table size do you use, and are you happy with it? And if not, is there a table size you feel would be better?
If it helps, I also plan to make at least two more movable tables of the same height that can be used to expand the work surface area. These tables can be slid into place. I’m thinking an extra table in front of the machine, and a second one positioned to the left side of the machine. I also plan to used these extra tables for a material cutting surface. My space isn’t super large, so I always plan for things to be multiple-use if possible.
The machine I own is a Consew 206RB-5. When I purchased the machine, I also got a selection of needles, some extra feet, and bobbins. I also bought a servo motor/drive and plan to use a much smaller pulley on the servo to slow things down a lot. I’ve read this is a smart move for the beginner like me. I also bought a set of really nice table legs that can be adjusted in height, and has the speed peddle. What I don’t have is the actual table top the machine sits into.
I have a bunch of North Western Maple left over from a large cabinet project I did a few years ago. I’m thinking this would be a great material to make a butcher block style top for the machine. With a couple coats of clear Varathane, I think the top would look nice too.
In my research, I found the most common size table top is 20” deep, by 48” wide, by 1 ¾” thick. There are also tables you can buy that are 20” x 52”, 24” x 48”, and even 36” x 60”. They all seem to be 1 ¾” thick. I can make this top any size. I don’t even need to use the steel legs I got. I can fab up whatever is needed.
Your thoughts and opinions would be greatly appreciated!
David
David
