Are you taking the pieces off of the boat to drop off to the sew shop? Or does the trimmer have to come to the boat to remove the pieces? If you take them, be sure to take both "sides" of the zipper. For instance, if replacing the zipper that connects the front panel to the bimini, you'll need to take the front panel and the bimini without the frame. Even if you think the half of the zipper on the bimini is fine, take both. If it really is as simple as removing old and laying in new zippers i would charge an hour plus zipper cost. That is assuming that no other repairs are necessary. Obviously if i have to go get the pieces off of the boat myself, you get to pay for that time too. When i do these repairs lime this i always go ahead and run a stitch down the other zippers on said panel as well. Doesn't take too much extra time and when one pops, they are all suspect.
