Hello! A beginner upholsterer here trying to sprinkle life into some old chairs. I’d like some guidance as to the best way to refoam and re-cover a seat base that is concave. If the foam follows that profile, will the fabric follow too, or try to lift up in the ‘hollow’? Or, should I cut the top surface of the foam to a ‘flat top’? Many thanks
#13111
@Shrekndonkey
If you are using scrim foam on your cover material something you can do is use the top of the seat when gluing your foam to the fabric as a sort of forming block. Or take a couple blocks of wood one on each side so the foam curves. This will help the foam somewhat take shape like you want. You can also shape the cushion with a slight dip in it to give it the extra shaping you want. Just some ideas. Hope it helps.
