By luis_upholstery
#12455
Hello, I’m trying to recover in vinyl 2 GMC Sierra door panels. I sanded down and cleaned with acetone and proceeded to apply landau glue to both panel and vinyl piece. For some reason the glue is not sticking to the door panel side. What can I do to fix this and make the glue to stick to the door?
What grit sand paper did you use? Are you allowing the glue to dry before attaching the vinyl to the panel? Some times those plastic parts a really greasy and hard to clean. You may have to use an adhesion promoter or primer first.
