By vicstric
#12204
Hey Guys and Gals! My lone functioning brain cell sputtered to life the other day and I started wondering if you guys use one stich length for seams and then change the stich length for top stitches? This made me think about tight curves. I have trouble with tight outside curves like at the corner of a cushion. They never look just right. Would a closer stitch work better? For the few years I have been dabbling, I just leave mine the same (around 6mm or about 1/4 inch). Some guys i watch in youtube seem to fiddle with the stich lenght a lot when they start to sew.
I recommend using 1/8 inch stitch length on all base seams and all top stitches with size 92 thread. When I use thicker thread I will adjust the stitch length larger to get the right look I'm going for. I think your 1/4 stitch length is too long and will make it difficult to make smooth curves. Also you should never adjust stitch length in the middle of the seam.
vicstric liked this
By vicstric
#12238
thank you @John , I will do that. Was always affraid to get the stiches too close together but maybe that will help me a lot.
No problem. Let me know how it works out.
1/8" is a good sweet spot for fabric and seam strength. If you go smaller you risk perforating the fabric making it easy to tare. But 1/4 is to long unless your sewing very thick thread.
John Long, vicstric liked this
By miket
#12250
Thanks for the question I have been having the same issue. I will try 1/8 as soon as I find which setting that is on my machine. LOL
