By Ddedman
#11534
so I recovered my sons headliner this weekend. Question for the experts.. the original headliner was made of foam backed fabric and a glued mesh type of fiberglass as the base formed structure. The fabric and foam had already delaminated leaving the fiberglass material. I glued the new headliner material to this and it shows most of the uneveness. What would have been the best way to prep this for a smooth finish?
By frankscustomupholstery
#11568
Yea the fiberglass with mesh type is a real pain in the neck. You must be extremely gentle when removing the old material and prepping the board. Yours looks good for a DIY job, and although it has a few bumps I have seen worse come out of supposed professional shops. Try steaming it to help soften the imperfections.
Yeah like @frankscustomupholstery said those headliner types are really bad to work with. There are 2 options I recommend to avoid this. If you can buy a new headliner board this is the best option.
1. Glue down a layer of 1/8 inch closed cell foam and sand out all the imperfections leaving a smooth surface.
2. If your looking for perfection you would have to lay fiberglass resin down and create a smooth surface using body filler.
By Ddedman
#11583
Thanks gentlemen. The majority of the imperfections or balancing out for the most part. I’m learning more every day.
By Kuph
#11585
As long as you can get the headliner stripped down to the fiberglass you should be golden. I use a wire brush and/or wire wheel to remove the degraded foam backing.
Sometimes the bottom of a broom or a old rag is abrasive enough to remove the sticky foam layer. Really anything works.
Image[/img]
By Ddedman
#11610
Yeah that type of fiberglass would have been nice. I was dealing with what I can describe as glued and compresses fiberglass insulation type material. Nothing really substantially firm about the sub structure. Yours looks as if it cleaned up nicely.
