By rnye
#11214
My Juki 1541S (15 years old) started puckering material. Changed needle, thread, checked tension, cannot find a solution. Has anyone had this problem with a Juki?
Based of that you have been using the machine for 15 years no problems an now there is a problem... My guess would be that the foot and feed dog timing have fallen out of sync. The manual should show how to check that but I usually just take my machines in to a repair show to get a tune up when this happens.
Another thing to check is the presser feet tension. If the presser feet tension is too high it can cause this problem.
hope this helps
Revv Up, Adam12 liked this
#11223
I find some of my problems are self induced, things like changing foot pressure or putting in a bobbin that’s isn’t wound tight enough (or too tight) changing needle and getting the wrong one or running through a lot of basting tape and gumming up the needle. Try to remember if you made any changes you can reverse along with what John said.
Adam12, John liked this
