By kl4bidn
#2760
My teriffic job is courtesy of The Lucky Needle Carpet Training Video Course. Thank you John for sharing your knowledge.
Took me probably 12 hours. This coupe had an air conditioning drain hose right up through the middle on the passenger side floorboard. I had to pad around it, hopefully I did it enough. Since space is a premium in a Coupe I didn't want to pad to much.
Also, fiberglass body needed padding out around every frame mount. The body had 1/4 recesses for this but then had 1/4" plate, 1/8" washer and 1/4" bolt head sticking out cover by 1 or 2 layers of Lizard wrap. I had to cut flush the Lizard wrap and pad appropriately.
And work around pedals, steering wheel, e-brake and A/C was a joy!
These are a few of things I'll be watching for on my next estimate.
hapyrdr, John liked this
