I have a small job coming up where a covered lid blew off the back deck on his boat and ended up in the street and looks like run over at least once. Anyway, he wants to replace with fiberglass or plastice (or other synthetic material) instead of wood. What would be the best material to use for ease of cutting curves, having a smooth edge after routing/sanding, and will take staples well? I have had mixed experiannce with sawing plastics. Some melt more than cut and kind of make a genteral mess on the edges. Often hard to clean up to a reasonably smooth edge. Others tend to chip out rather than cut.
Ideally, id like something that I can cut with a jigsaw and sand the edges. Not sure there is a plastic that take well to sanding. Ihave a router but that would require more time i think.
#1761
A thought occurred to me that made me remember this post. I have always been a big advocate of recycled plastic products and one of the things that can be made with recycled plastic is plastic lumber. Now, in my experience this stuff isn't great long term in the sunlight as it fades fast and unevenly. But to use it as a seat bottom or hidden structural piece would be awesome. There are quite a few companies out there selling this product and I would be interested to see how it works out. Share your experience with it if you go that route, I'll have a boat to do when I get back to NC this fall and will try this my self.
vicstric, LeatherJohnny liked this
#1845
Wow! What an eye opener it was to see how expensive a sheet of plastic is. I thought foam was nuts...lol
Long story short i looked into Starboard. Turn out through a local supplier that they dont carry it but they can get it. $280 a sheet and min order is 2 sheets. I did some researching and I believe it is made from HDPE plastic. HDPE is supposedly easy to machine which was a primary concern for me. So i asked about just a sheet of that. $230 a sheet and they had some in stock. I called the customer and he said that was ok, so I picked some up.
I neglected to get pics of the cutout piece but it was in fact easy to work with using a jigsaw and sanded ok to a degree. Anyway, I wanted to send out a few pics of the project. I was pretty happy with it.
