By Gksportster
#10281
Thank you Cody you did a great job on the door panel.
Yea it takes a lot of work to finish a car exp when mine was a frame off and repaired a lot of cancer that no one makes repair panels I had to use 18 gauge metal and run through a English wheel to get the compound curves I put a mustang 2 frount end under it a 06 6.0 ls motor in it with a 4l65e transmission and a 10 bolt rear end also with triangulated 4link and coil overs.
I have found out the weakest part so far is the rearend I’ve snapped a axel in half
Dang those splines are twisted. Don’t see that too often. That 6.0 is a good motor to be running. Just put a 5.7 in a 55 I’m working on.
By Gksportster
#10289
Sweet I like it looks like you have more room then I did on mine.
I want to put a turbo on it but I have no room.
Maybe my next project I have a 71 satlite road runner and I have a 50 Willy’s pu with 85 k 5 blazer running gear under it
